Differential Fluid change
chandr
10-25-2005, 12:12 PM
Dear Members,
My car model is 1998 Camry XLE. One month back I flushed the Transmission fluid and replace it with new fluid.
I am not having knowledge about the differential.Do I need to change the Differential fluid?
Please give me your suggestions.
Thanks
Chand
Toysrme
10-25-2005, 06:26 PM
You don't. By '98 they had intigrated the differental supply with the A/T supply. Tho the diff still has it's own drain plug, it is filled with the transmission supply.
Just keep adding to the transmission supply until it reads normal.
That means bring the car up to temp by drving around the block. parking. Shifting through all gears & THEN checking the transmission fluid level.
chandr
10-25-2005, 06:55 PM
Hi Toysrme,
You are really great. Thanks for your help.
Chand
