1989 O2 sensor info...
ohanahorse
10-25-2005, 10:17 AM
I'm looking for information on the O2 sensor. My check engine light comes on about every 15 minutes and will stay on unless I back off of the gas pedal, in which case it immediatley goes out until the next 15 minutes. I checked the code sequence and it said O2 sensor (check O2 sensor wiring and/or replace). Since it is a somewhat primitive OBD, I'm wondering if anyone else has ran into this issue. If so, what was the resolution...
Thanks.
89trooper
10-29-2005, 06:09 AM
Replace the O2 sensor already! It has lasted 15 years. They aren't too expensive or too hard to replace yourself.
ohanahorse
10-31-2005, 10:26 AM
Thanks for responding. I'm trying to learn what is going on. According to my book, if it needs replacing the light should stay on. Since it goes off each time I take my foot off the gas, I thought it may be related to something else. The book suggested to "check the wiring"..nothing more specific than that. Happy to replace it, and indeed it is simply, but I want to understand, rather than replace for no reason and add to the landfill.
89trooper
10-31-2005, 12:26 PM
It is a one wire sensor on this vehicle. I supposed the wire could be laying on or near the exhaust manifold and could be shorting out. This is normally not the case though.
