1986 B2000 crank gear
Honest Lou
10-24-2005, 06:09 PM
Can someone tell me the torque spec for the timing gear on the crankshaft. I need to replace it due to a sheared key. Also what method do you use to hold the crankshaft to get the bolt loose.
thanks
thanks
scooter493950
10-25-2005, 10:18 PM
thanks
according to my service manual the torque for the crankshaft sprocket bolt is 116-123 ft.lbs. , As far as holding the pulley, they make a pulley grip tool that looks alot like a oil filter wrench. I have always used air impact to get the bolt out.
thanks
