3 problems with 93
Retard324
10-23-2005, 07:00 PM
so i just bought a 240 today, its my managers from jiffy lube. when i brought it home an was checking everything out, spark plugs, air filter, etc. i pulled the wire out of the second cylinder.. and out come around a tablespoon of oil! the spark plug is drowned in oil... wtf, how can i fix that? and also, whenever you press in the clutch.. a drop of brake fluid comes out. i was told to replace the seals in the slave cylinder, i dont know if thats right. also the passenger and driver side doors, dont unlock when you turn the key. you have to get in through the hatch. how could i fix that? thanks.. so happy with my new 240!
R.W.240
10-23-2005, 07:55 PM
1) Spark Plug well gaskets and/or a ton of RTV.
2) If the leak comes from the slave cylinder area then yeah that would be it... or if you plan on modding you could get the Nismo.
3)Leave the windows down and dont leave anything worth stealing inside :dunno:
nissan_240sx
10-23-2005, 09:41 PM
3.
your door locks are prolly fucked, where you stick the key in. just remove them and bring it to a locksmith, they will repare it. give them your key so you wont have to use seperate keys for your doors and ignition. i know this cause i changed one of mine
peace
240SXSlideStar
10-23-2005, 10:56 PM
I dunno how it is on an S13, I haven't done mine, but on some cars, you really need some tiny ass arms to get the the lock cylinder, lol.
nissan_240sx
10-24-2005, 03:24 AM
hell yeah tiny arms are a must LOL, got help from my little cousin. the real bitch is re-connecting the clips from the lock to these metal rods. took me a good 40 mins
Tgreaser
10-24-2005, 04:21 AM
first off whoever told you that is a moron, don't listen to them again and walk away lol. You need to find where the leak is actually comming from, if it is the master cylinder, line, or slave cylinder. Replace the entire component that is failing, "replace the seals" lol thats a good one.
FixUrNissan
10-24-2005, 05:29 AM
As for your Nissan 240 , 3 Easy fix's.. First your oil leak into your spark plug Galley.. thats just a matter of replacing your valve cover gasket.. when you have teh valve cover off you'll see a second gasket that going around all 4 spark plug holes.. oil seeps into spark plug galley when they are bad. Next Your Clutch.. Pretty cut and dry.. Clean your clutch master and slave . If the slave starts to drip , there you go . Replace your slave. Last but not least your lock.. The hardest part of this is removing your door panel, sounds like the rod just pop'd of the lock cylender.Just a matter of getting the door panel off and hooking it back up..you said the lock turns with the key so it's not the lock. GL
Retard324
10-24-2005, 11:20 AM
the brake fluid drips out of the rod thats connected to the clutch pedal. thats probaly a bad explanation but i suck at explaining things and i dont have a digital camera to post pics.
