1994 grand am head lights
armagh
10-22-2005, 08:52 PM
All of a sudden my head light stopped working. if I turn them on and open the door the alarm goes off telling me they are on.
Is there a fuse for them if so which one is it.
How do I take the head light out to check the bulbs?
Thanks
Thanks
pgram
10-24-2005, 04:14 PM
Thanks
You have the same problem many others have had. The multifuntion switch that turns on your headlights/high beams/cruise control/ directionals is fried. Buy one at Autozone and have a mechanic install it or possibly do it yourself. There is a thred here where someone has given directions on how to disassemble steering column and install new.
Thanks
armagh
10-24-2005, 05:33 PM
thank you
thank you
catback23
10-24-2005, 06:03 PM
Maybe you'll get lucky and its just the bulb so I'd check that first.
skibum1111
10-24-2005, 06:20 PM
The headlight switch is easy to install, and you don't have to remove the steering wheel, despite what other people tell you. I did my 95 without taking the wheel off, you need a torx driver, like a screw driver to get the screws out of the column, and a torx bit and pliers to get the screws out of the switch, and a little patience.
armagh
10-26-2005, 01:49 PM
OK THANK YOU
OK THANK YOU
