Ahhhhhhhh!!!!
driftking777
10-18-2005, 07:27 PM
So i took my car for a test drive after fixing an oil leak, when i reved my motor and all the sudden my car almost died. doesnt want to run...and when running runs like compelete ass. when running (only runs when gas is pressed) blows black smoke...im thinking possibly to things happened...my CAS went out...(do they go out suddenly like that) or my coil went out, not allowing to spark properly...was running fine...then all the sudden pow...this happened...can anyone help me out here?
AWDSR20
10-18-2005, 09:33 PM
blown head gasket?!?!
driftking777
10-18-2005, 09:58 PM
btw...im blowing oil...not sure if its from the head gasket or valve cover...if head gasket is blown...would it run like this...(possibly becuase no compression)
nissanfanatic
10-18-2005, 10:24 PM
Pull your plugs and examine. Compare appearance. Sounds almost like a crapped out lower O ring.
Check for spark as well or test coil pack(s) resistance.
driftking777
10-18-2005, 10:26 PM
yea i was also going to test the coil packs...kinda sounds like there crapping on me..
AWDSR20
10-19-2005, 02:19 AM
coil packs are expensive....
HoosierDrifter
10-19-2005, 03:09 AM
black smoke means its running rich... your problem sounds like when i had my MAF wiring wrong... check that your maf is putting out a signal.... if it is.. then check continuity from your maf to your ecu... just to make sure that its not broken off somewhere... check your passengers side innerfender above your wheel because there is a wiring harness right there and the maf wire is right there inside it.... beleive me.. i almost rubbed through my maf wire when i had my suspension real low
driftking777
10-19-2005, 08:15 AM
awesome...thanks for the help on that guys...im giong to have to check all this stuff out...so i have a few things to check...check for some intercooler piping off ect, maf, tps, ect....i'll def be checking the plugs too...just sucks...my cars been down for a fuck oil leak for a month now...i get that fixed...bam new problem within 10min...
wotandsdwys
10-19-2005, 02:39 PM
something with air intake or spark.
white smoke is headgasket.
