AIR DRIED BEEF DOG FOOD
2001 Blazer dies after startup
Cercion
10-18-2005, 06:36 PM
I've read the forums and think my ignition switch is going bad. However, I have a extra symptoms I haven't seen in other posts.
Sometimes when starting the blazer it will die repeatedly or it will start up weak and sputtering and then die. In both cases my dash inditcator lights go nuts, ABS, BRAKE, SEATBELT, Check Gauges, ENGINE, lights all come on and go off at different times. Also, it will sometimes reset the time on my clock, as if I unplugged the battery, and engine nosie can be heard through the speakers The stealership wants me to bring it in but I'd rather fix it on my own if possible. Thanks guys!
Cercion
10-18-2005, 06:46 PM
It has worked properly for quite a while now with new ac delco plat plugs and bosch wires
Cercion
10-18-2005, 09:26 PM
Also a few weeks ago had a connect problem with the signals.... could've been a loose wire or an intermittant problem now coming to bite back
BlazerLT
10-18-2005, 09:30 PM
So everything is good now?
Cercion
10-20-2005, 04:56 AM
The turn signals work but I'm having the problem at start up where it will die. It doesn't happen everytime I start up the car but when it does, it will happen several times in a row. The turn signals were a seperate issue a few weeks back.
