Doors make popping noise
rodeodan888
10-18-2005, 10:49 AM
I have a 99 Rodeo LS. My front doors make popping noise when I open them. I searched this site and found I need brass brushings. The problem is I could not find the plastic bushings on any of the four doors, so I do not know where to put the brass brushings. Are there two brushings for each door? Are they outside or inside the hinge?
Thanks,
Dan
Percon
10-18-2005, 02:42 PM
Thanks,
Dan
I have the same problem before on my 98 rodeo LS. all i did is tightin the 2 bolts in the hinges in the door did you try that.
Cat Fuzz
10-18-2005, 10:46 PM
You would need to remove the door and the door hinges in order to replace the bushings.
