tranny
cutoff
10-17-2005, 08:27 PM
my tranny(gpgt97 vin k)it is the same to bonneville 3.8 vin k 2003
cutoff
10-17-2005, 08:49 PM
because in the alldata.com the free demo car is 2003 Pontiac Bonneville V6-3.8L VIN K
maxwedge
10-17-2005, 08:50 PM
May be some differences in the electronics, also could be 4t65e in one and/or 4t60e in the other.
BNaylor
10-18-2005, 07:32 AM
Like Max said there will be differences between your tranny and the '03 Bonneville. Even the wiring diagrams will be different. Check the SPID label located on the back of the trunk lid or spare tire cover for the tranny RPO option number. Somewheres on the second line or so you should see M13, M15, etc ??? The '02-'03 Bonny Vin K has RPO MN3. A GTP Vin 1 has RPO MN7.
Depending on when your GT was manufactured in '97 it could be a 4T60E or 4T65E.
http://i5.photobucket.com/albums/y186/lizzywiz/gtp.jpg
Thrasher CAI, DHP v1.0 PCM, SLP Headers,
3.25 SC pulley, CAIT GMAF, 2.5 DP/Hi-Flow CAT,
u-bend delete, 160 TS, ZZP Stage 1 72mm TB,
TB spacer, MSD 8.5mm wires, Autolite 103,
Goodyear Gatorback Serp. & SC Belt,
Nitto NT555R Drag Radials
1/4 ET: 13.210 sec. @ 104.490 mph
0 - 60 ft: 1.945 sec.
