Timing chain noise
57r337.Dr1f73r
10-17-2005, 01:35 AM
Hey I just bought a 93 240sx fastback with 147k miles and it has a intermitent rattle sound coming from the front of the engine right around where the timing chain should be around 1300rpm. I removed the valve cover in search of the sound. While running the engine I broke out the stethoscope and began poking around again and heard it near the timing chain. I read that this could be the chain slapping because the guide broke. Is this generally what it is? While i've got the engine apart should I just replace the timing chain? Or can I get away with using the old chain?
nissanfanatic
10-19-2005, 09:30 PM
Timing chain rattle is normal. Just check to see if the top guide is still there. If it is, remove it. Two bolts hold it in place right between the cams. It is no longer included in timing chain kits either.
57r337.Dr1f73r
10-19-2005, 09:41 PM
Hey thanks for the help.
4Wheel
10-26-2005, 01:11 PM
Dude It's your muffler bearing.
4Wheel
10-26-2005, 05:37 PM
I sat here for 15 min trying to figure out a reply. I'm still workin on it, i'll have it next time you come over.
4Wheel
10-27-2005, 12:39 PM
lol i'm still in your account WHAT NOW!!!
OK so I forgot to log out and you decided to post a picture of the car you just bought as my signature.
C.G.E. Cardboard Ground Effects.
Look I told you that $12.3k was TOO much but since the guy decided to throw in the "body kit" it is well worth it!
Nice ricer!
Nice ricer!
nissanfanatic
10-27-2005, 05:15 PM
WTF?
-Closed
-Closed
