92 GA SE A/C relay........
jbmx4life
10-17-2005, 12:00 AM
I am having trouble locating the relay mentioned above. The reason that I am looking for it is because my A/C has stopped working. I checked the fuse and that is good.
Autozone.com component location (http://autozone.com/servlet/UiBroker/?UseCase=C001&UserAction=answerRequiredQuestion&Parameters=%7C%7ECONTROL&PageSync=6)
Image from gmpartsdirect.com for location (http://www.motorplace.com/flow-pcx/parts_catalog_components.cgi?1129521259819#) (it is supposed to be the top picture according to autozone's decription)
^^ That is what I found so far on dealing with this relay. If there are any other suggestions I am more than open to them at this point in time.
Jeremy
skibum1111
10-17-2005, 05:25 PM
The realy should be on the right side (standing in front of the car) against the firewall, there is a bank of 3 relays. The ac relay is the middle one (I believe), 2 of them are the same, swap them and try the ac, if it doesn't work, check the ac to make sure its charged.
jbmx4life
10-17-2005, 11:00 PM
nope sorry there are no relays under the hood. If you go to the autozone link it says that it is inside the passenger compartment and I am guessing that they are right in that description because there are no realys under the hood. Thanks for trying to help tho....
Jeremy
