99 ABS Light
kymagred
10-15-2005, 09:34 AM
Back again. This time its the ABS light. It comes on when we start to rolling and stays on. A few weeks ago I shut off the Expy and it stayed out, now it stays on. I did a search here a got some info. Is there a special scanner for the ABS. I stopped at Auto Zone and ask if they could find a code with their scanner and was told it would not work. Do I have to take it back to the dealer to find out what's wrong? Thanks T
way2old
10-15-2005, 04:43 PM
Not necessarily a dealer, just some placethat has the ABS software installed. From your description it is probably wheel speed sensor, but without a code, it is hard to tell which one.
kymagred
10-19-2005, 01:35 PM
"Not necessarily a dealer, just some placethat has the ABS software installed. From your description it is probably wheel speed sensor, but without a code, it is hard to tell which one."
I feel you are right. Can I go to the dealer and pick one up and move it from wheel until I find the one that is bad? Or will the R/ Fornt not fit L/ Rear? Just asking, T
way2old
10-19-2005, 05:38 PM
I think both the front are the same and both the rears are the same, but the front and rear are not the same.
