Map sensor, need asap
rustylane
10-13-2005, 12:57 PM
I got a code 34 on my 93 Bravada. Means the mpa sensor is bad. I know where its but wanted to know if this will cause it to serge and stall at idle. It runs rough at speed but does ok.
maxwedge
10-13-2005, 01:31 PM
Yes, and make sure the hose is attached and has vacuum to it.
rustylane
10-13-2005, 07:06 PM
There is no hose it attaches direct to the intake manafold, but thanks for you help in this. Ill let you know what happens
