dipstick keeps popping out
Lewis_17
10-12-2005, 10:26 PM
i've noticed recently that after i've been driving around for awhile, the dipstick will be popped about an inch out of the tube. what would be causing this?
AzTumbleweed
10-13-2005, 06:26 AM
When I first saw the heading "Dipstick Keeps Popping Out" I thought you might have a broken zipper! :lol2:
Seriously, It's possible you have some pressure inside your engine that could be caused by a bad PCV valve. You get pressure from the blow-by going by the rings. The only place for this pressure to go is out the PCV valve. So I'd check/replace it. Also, a few of us here have had problems with the hose collapsing between the PCV valve and throttle body.
Lewis_17
10-13-2005, 03:51 PM
i replaced the pcv valve about a week after i got the car, so should i replace the hose between the pcv valve and throttle body?
AzTumbleweed
10-13-2005, 05:29 PM
Only if the hose is collapsed. I woner if you got the wrong PCV valve?
Lewis_17
10-13-2005, 11:59 PM
the pcv valve i got looks exactly like the old one
