Swaping Auto to manual trans hlp
240sxGA
10-11-2005, 05:05 PM
:screwy: Hows it going guys? I have a question about my 1996 240sx. I plan on doing a sr20det swap soon. The thing is that its an auto trans. I belive I have just about everything. I have a clutch pedal, master cylinder, the two lines and Im gonna go ahead and buy a new clutch for the manual. I'm not sure what else I need. I just wonna make sure I have everything before I buy the motor,trans,& ecu, because if I could do that It wold be cheaper than buying a whole front clip. So the basic quistion is....what all it will take to swap it to a 5-speed?
LT1-Power
10-11-2005, 06:08 PM
i would have bought a NEW clutch master cylinder, as well as braided stainless steel clutch line(master to slave). Your also going to need a clutch slave cylinder, i would also get a brand new one of those to put on there.
Hopefully your clutch kit has a new throwout bearing and pilot bearing. If not get them. Also I would change the rear main oil seal while you got all this shit out. Lightly sand the flywheel with a DA sander to smooth it out and polish it up. Hopefully it is not too far gone and the teeth are in good shape if you are not buying an aftermarket one.
wiring will be self explanatory if you get the complete uncut wiring harness.
LT1-Power
10-11-2005, 08:38 PM
also if u want some tips:
I would take the transmission off the engine out of the car, do all of this work, then re-assemble it, then put the Motor/Tranny combo into the car. I personally like to remove the transmission first. In the end you still do the same amount of work, but it makes taking the engine in and out a BREEZE without the transmission attached. The tools I have make it easier to remove transmissions quickly though, so I would do it outside the car if your not an einstein at it to save you some time.
I've heard horror stories on here about people trying to take off bellhousing bolts with wrenches and stuff..... don't try that at home. If you lack the equiptment and experience on taking transmissions out, taking it apart out of the car makes it easier to get the bellhousing bolts off, as well as work on the clutch/flywheel/oil seal.
you might already be planning on this but if you already are its a good plan.
240sxGA
10-11-2005, 08:41 PM
Yes my clutch master cylinder is new and I already bolted it up. OK Just so I dont have to keep asking, is there a good website for what Im doing. Ive found some for just doing the swap but that shouldnt be the problem I just want some more information on the tranmission swap but any information is good.
thanks.
240sxGA
10-11-2005, 08:47 PM
yeah, thats what I was planning on doing. I have all the stuff and can do it I was just gonna make sure I wasnt missing anything. Im just new with the Sr20 swap. Were can I get all the clutch and slave cylinder from cause Im sure its not the same as a KA Manul trans?
LT1-Power
10-11-2005, 09:55 PM
Nismo CLutch line
http://shop.store.yahoo.com/import-store/nistcllifor8.html
also a mod u can do, I would defintely do this when doing auto to manual swap. The moderator, nissanFanatic, i believe has done this and loves it, ask him some more about it.
http://www.nostreetracing.org/forums/article.php?a=11
240sx clutch master cylinder
http://www.courtesyparts.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=CP&Product_Code=30610-00008
Nismo Slave Cylinder
http://www.courtesyparts.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=CP&Product_Code=30620-SR20T
you will also need the clutch fork, this is what the slave cylinder pushes on and it is a metal piece that sticks out of your transmission. If yours has this cool, it might not. If it doesn't, I MIGHT have one off a misc. 240sx transmission that could work I could send you.
