brake fluid to stip paint?
crazyheck
10-10-2005, 06:21 PM
i thought i read that andy jones had used brake fluid to get a model back down to plastic without actually hurting the plastic can someone verify this for me before i actually do it?
mike@af
10-10-2005, 06:48 PM
By using the search feature you could have found this answer.
Yes, brake fluid strips paint without harming plastic.
Vric
10-10-2005, 06:59 PM
Good read here (and talk about brake fluid)
Strip Paint (http://www.scalewiki.com/wiki/index.php?title=Strip_Paint)
g00eY
10-10-2005, 07:35 PM
brake fluid works real good and i haven't harmed any models. just don't leave it in the fluid for too long. and it smells bad and is probably poisonous so don't swallow any or something stupid like that and you should be fine.
freakray
10-10-2005, 07:52 PM
PLEASE USE THE SEARCH FEATURE.
Thank you :iceslolan
D_LaMz
10-10-2005, 09:53 PM
Watch out for clear parts though
chyknees
10-11-2005, 12:38 AM
i haven't had a problem with brake fluid ruining the plastic and i've left my models in it for more then a day. Depending if you have glued some parts onto the body it might come off, depending on the type of glue that you used, it has happened to me a few times. Like my lip or mirrors would come off after.
