over heating HELP?!?!
maverick27
10-10-2005, 03:52 PM
ok so my 97 gst with 115000 miles on it has been having an over heating problem for about a month now. i see a leak coming from the water pump so i change out the water pump and after was doing good then i notice my heat up agian. i pop the hood and cant see any leaks from the radiator or hoses. it has been a week since the change of water pump. what could it be? thanks for ur help guys.
SLoe
10-10-2005, 07:42 PM
Check your thermostat. It may not be operating properly. Hell just replace it, they're cheap. Also when was the last time you flushed your radiator?
l_eclipse_l
10-10-2005, 11:14 PM
Good advice.
I remember my old 97 oldsmobile, the radiator had never been flushed since my dad had owned it, and by the time i got it, there was this like mud shit throughout the radiator. Flushed it soon after I got it.....no problems. BTW, it had 123,000 on it when i got it. Looooong time to go without flushing.
92SilverTsi
10-11-2005, 04:14 PM
I have had the same problems, and when everything was said and done, it was a hair line crack in a hose (usually running out of the radiator or thermostat housing). I have noticed with my car that if a clamp is not tight enough or a slight crack is in a hose it will overheat (no matter how small!)... RE-Checking all hoses and clamps and ensuring fluids are full would be my suggestion after all else fails...
spyderturbo007
10-12-2005, 08:06 AM
With 115k, you might want to look into a compression test, just to rule out the HG.
http://www.dsmgrrrl.com/FAQs/compression.htm
