back fires
shaolyn
10-10-2005, 02:31 PM
okay i own an 89 240sx and i swapped in the sr20det and had no problems with it in the beginning now its backfiring alot what do you think it is?? any help would be appreciated thanks
240SXSlideStar
10-10-2005, 09:01 PM
Recirculate your BOV to the intake pipe.
Tims_240
10-10-2005, 10:37 PM
check all of your intercooler pipes and couplers for leaks (http://forums.nicoclub.com/zerothread?id=113785 )
sounds like you have a boost leak, or does it backfire after you shift?
because if it does its most likely your aptmospheric bov.
R.W.240
10-10-2005, 10:38 PM
Fouled Sparkplugs - If you dont recirc the BOV then you'll go through them every three months or so...
Also it may be the colder weather.
NissanElitist
10-11-2005, 01:41 AM
Backfiring under acceleration - Suddenly retarded timing, more than likely it's knock or something electrical.
Backfiring while shifting - Normal
