Fan won't work on low setting
gkirkbride
10-06-2005, 04:15 PM
I have a 2001 Olds Alero. The fan has 5 speeds (six if you count the off position) and it will not run on the lowest speed. I replaced the fan switch, but still won't work on lowest speed setting. Anyone have any ideas?
GTP Dad
10-06-2005, 05:56 PM
Replace the blower resistor. It should be located under the dash next to the blower fan. The speeds will slowly go out until all you have left is high. The resistor will cost about $40 at a dealer.
