Straight Pipe instead of cat?
RG501
10-06-2005, 03:34 PM
would do i need to do to put a straight pipe in? do you just take out the cat converter and put in a pipe? what kind of HP gain will it give me and will it sound diffrent? where can i get a straight pipe?
maxwedge
10-06-2005, 04:14 PM
Little or no power gain stock, also a Federal offense!
Mr. Luos
10-06-2005, 05:27 PM
It will sound different. You will gain power. Some states it isn't illegal.
CreepingDeath94
10-06-2005, 05:48 PM
I think there is still some sort of AIR system that pumps air to the cats on the 4th gens isnt there? If there is, you cant just let that blow in the air. Plus the check engine light may come on if the O2 sensor after the cat, once again if there is one past the cat, isnt reading as it should post cat.
Mr. Luos
10-06-2005, 06:06 PM
The AIR system is on the mainfolds. Not the cats.
You would have to adjust the computer or get rear O2 sims.
maxwedge
10-06-2005, 06:50 PM
MR LUOS, fyi cats are federally mandated, not under state control, the state is mandated to over see the regs.
RG501
10-06-2005, 07:16 PM
will it sound better than stock? how much power gain will i see?
KaotiKCamaro5
10-07-2005, 02:55 PM
if you have a cat-back exhaust system it will sound better with the cat off (a little more raspy/deep).. but i have no idea what its gonna sound like if you have the stock exhaust.. and honestly, you wont see or feel a difference in power.. i removed my cat about 2 years ago, shortly after i got my exhaust..
blindeyed
10-07-2005, 10:10 PM
I live in Florida.. and I have no cat. Greatest thing about it, it's not illegeal. Yes car companies are required to put cats on their new cars. BUT, once someone buys that car, it's up to them to decide if they want to remove it, given of course that it's legal in their state to do so.
As for HP gain, well.. you won't see any difference at all, as most others have already said. I actually wish I had one. The way my exhaust goes, it's 2 1/2 from the Y-pipe, and then theres an adaptor that makes it go to 3 inches. It doesn't look all that great, kind of a sloppy welding job around it. But if I had a cat that had a 2 1/2 inch inlet and then 3 inch outlet, it would look alot better. So I would have to say it would be wiser to just go ahead and get a cat, unless of course you blow all your money on an expensive exhaust kit and cant afford one (like yours truly).
Multiphat
10-07-2005, 10:38 PM
Will be louder exhaust sound. May notice gas mileage increase and power increase if there is some clogging in the catalytic converter. Check local laws, it may cause inspection problems.
RG501
10-07-2005, 10:47 PM
the reason why i asked this is because my firebird has about 110k miles on it and it still has the stock cat on it i think. i dont think the original owner ever replaced the stock one. so im thinking maybe mine is starting to get clogged or something.
Multiphat
10-07-2005, 10:53 PM
Change it. Cats are only designed for 100,000 miles. Get a high flow cat to replace it with. You may be suprised by the difference in response and during heavy acceleration.
RG501
10-08-2005, 11:44 AM
what are some high-flow cats you'd recommend?
Mr. Luos
10-08-2005, 11:46 AM
Random Tech.
blindeyed
10-08-2005, 12:24 PM
I hear carsound makes some pretty nice cats.
