GSR newbe
B16Z6+S20
10-05-2005, 12:16 AM
hi, i just traded my coupe for a GSR, so i got a few questions. first, where can i find the fuse maping. i mean the paper thing under the stering whell thet lets u know for what is each fuse for, (its a 99 two door GSR). and also the RPM gage doesnt work so if any 1 knows where to start cheking for a lose wire or something, and also at what rpm Vtec kicks in? so thats it for now. thanx for ur time guys hope to post again soon.
P30n
10-05-2005, 12:29 AM
around 5800 for vtec from what I heard
pepsihatman
10-05-2005, 12:57 AM
I always thought vtec engaged in two stages with our engines. One stage at 4400 rpm, the third lobes engaged, and then at 5800rpm or so some extra intake valves open up (most people see this as vtec engaging)
superbluecivicsi
10-05-2005, 05:38 AM
go pick up a helms for $60. best $60 you will ever spend.
B16Z6+S20
10-05-2005, 08:19 AM
whats a helm?? and also wich wire on the ECU is the one for the exaust sensor?, so i can conect the mixture gauge, and wich is the vtec wire?
knorwj
10-05-2005, 08:41 AM
you have it backwards. 4400 is where the dual runner intake manifold opens up more to allow a little extra air in. 5800 is where the vtec kicks in.
pepsihatman
10-05-2005, 12:38 PM
Ok gotcha. But it is two stage!
To answer your question, a helm is a manual for the car. It is like a a Haynes repair manual. Helms manuals are good.
V T E C H
10-05-2005, 05:59 PM
i thought at 4400 rpm is where the "secondary butterfly valve" or somthing like that opens up, then at like 5800 is where vtec really kicks in. just what i have read some where.
knorwj
10-05-2005, 08:58 PM
ummm just skip back two posts man...
B16Z6+S20
10-05-2005, 10:41 PM
thats all great to know thanx guys but i erally need some help if any1 can direct me to a ECU diagram will be great. and also i still dont know whats a helms and what is it for?. im gona check e bay. thanx again
pepsihatman
10-05-2005, 11:31 PM
I said previously, when he said "Helms" He was refering to a "Helms Manual." It's a repair guide for the car.
superbluecivicsi
10-06-2005, 12:22 AM
a bible for any honda/acura home mechanic.
~ls/vtec~
10-06-2005, 02:32 AM
one that would have diagrams that youre asking us for...
knorwj
10-06-2005, 11:38 AM
even a 14 dollar haynes manual would have the diagrams if you don't feel like splurging for the helms.
B16Z6+S20
11-12-2005, 06:44 PM
i think you guys are wrong about the vtec, it engages at 4400, i tested mine and at that rpm is when it kicks in.
pepsihatman
11-12-2005, 08:32 PM
This thread is a month old...
knorwj
11-13-2005, 03:16 PM
i think you are wrong. go back and reread the posts in this thread and you will learn what is engaging at 4400.
the only way that it could engage at 4400 is if someone reprpgrammed it to do so for some reason.
B16Z6+S20
11-15-2005, 05:58 PM
well i conected a ligth to the vtec sensor and it comes on at around 4400 RPM if it is a second buterfly why is the sensor engaging?? , you can check just by conecting a wire to the sensor with a ligth bulb and ground it to where whever u want and check it for yourself
Tano016
11-15-2005, 06:58 PM
On a Gsr, the pins engage through the rocker arms at 4400 rpm, which creates high valve lift from the center lobe on the cam making contact with the center rocker arm. This is what is meant by VTEC, it kicks in at 4400rpm. The intake manifold changes profile at 5700rpm, from long runners to short.
In a Type R the whole VTEC lobe thing happens at a higher 5700 Rpm, since the primary cam lobes are bigger than that of a Gsr. There is no Variable Intake manifold on a type R.
pepsihatman
11-15-2005, 08:41 PM
That's exactly what I thought.
