Is it possible???
mike561
10-04-2005, 04:48 PM
Ok, i know this would be EXTREMELY expensive to do, and maybe even a dumb question, but would it ever be possible to put a V8 engine into a 98 GP???
GTP Dad
10-04-2005, 05:10 PM
Anything is possible and like you said it would be very expensive. If you have the money why not put a SC 3.8 in your car. Much easier to do and parts are readily available. You can mod the 3.8 and it would give you V8 performance.
BNaylor
10-04-2005, 05:35 PM
Someone, only the Lord knows why, did in fact put a small block Chevy V8 (LT1/LS1) into a late model Grand Prix. He even put it up on Ebay for around $26K. The engine was where the back seat sits and it was converted to rear wheel drive. So it has been done and for big bucks.
http://i5.photobucket.com/albums/y186/lizzywiz/gtp.jpg
Thrasher CAI, DHP v1.0 PCM, SLP Headers,
3.25 SC pulley, CAIT GMAF, 2.5 DP/Hi-Flow CAT,
u-bend delete, 160 TS, ZZP Stage 1 72mm TB,
TB spacer, MSD 8.5mm wires, Autolite 103,
Goodyear Gatorback Serp. & SC Belt,
Nitto NT555R Drag Radials
1/4 ET: 13.210 sec. @ 104.490 mph
0 - 60 ft: 1.945 sec.
mike561
10-04-2005, 05:46 PM
yeah i have the 3.8 supercharged model already, so i can probably do better mods with that im sure
icecreamman33
10-13-2005, 11:22 AM
I wasn't an eye witness but, I've read that the cadillac northstar V8 is a direct bolt in match. With wire harness and PCM installed as well. Also read you don't get much more power than the super charged 3800
Madmunky
10-13-2005, 12:44 PM
There is a guy on Cardomain that is putting a Cadillac engine in a 94 GP, can't remember the users name, but the opening line is "Trevs Cadillac" or something along those lines. I would get the link, but I'm at work with dial up...it would take too long to find the link.
