1990 F150 Guages not working HELP!!!!!
rdharley3
10-04-2005, 01:05 AM
I have a 1990 F-150 XLT about 2 months a go I had a problem with the tail lights not working after many hours I discovered that the ground lead from the trailer harness was crushed after fixing that problem and resoring the tail lights in about a week every guage except the speedometer quit working on the instrument panel, fuel, voltage, temp., oil pressure, and RPM.
I have checked fuses and all are good....
ANY HELP WOULD BE GREATLY APPRECIATED....
RDH
blackdragon258
10-04-2005, 06:06 AM
Not that this is a huge help since I don't have the answer to your question, but I can tell you why the speedometer works out of the guage cluster. The speedometer is a single pair of wires that run from the dash to a sensor mounted on the top of the rear differential. Thats why this still works, because it isn't wired in with the rest of the guage cluster.
rdharley3
10-04-2005, 12:17 PM
Do you know if there is a module that controls these guages???? I can see 1 guage going out but all of them at the same time and no blown fuses?????
RDH :banghead:
blackdragon258
10-05-2005, 12:28 AM
I honestly don't know. Have only had the truck for 2 weeks. Sorry.
Saw this posted in another forum on here. Look for it here: http://www1.autozone.com/servlet/UiBroker?UseCase=RG001&UserAction=processModel&Parameters=012
