94 CUTLASS Battery Drain
blackhillsdeb
10-03-2005, 02:39 PM
I have had my 1994 cutlass supreme for about 3 years with no problems. It has just started with a battery draining problem. It will be ok all week if it is driven daily, but if it sits for a day without being driven the battery is dead. I first of all thought it may be the battery, so I replaced that. That did not help. By the weekend it was again dead. Can anyone please help me? I am so frustrated. What ever informational help I can get would be greatly appreciated.
quicksand
10-05-2005, 12:02 AM
did you check the alternator
GTP Dad
10-05-2005, 08:49 AM
Any battery drain is caused by something pulling voltage. If it drains as fast as you say there may be a light on somewhere in the car. Check the glove box, trunk light, under hood light. If they are all off when they should be you will need to do a systematic test by checking each circuit. To do this pull each fuse and check the circuit with a volt meter to see if there is any draw on that particular circuit. This takes time and if you have a dealer do it, it will cost a lot of money.
blackhillsdeb
10-05-2005, 07:40 PM
did you check the alternatorWe just weren't sure if it was the alternator or not. As of yesterday it would not charge at all, so we did buy a new alternator today, We have not put it on yet. Hopefully that will take care of the problem. If not, I suppose we will have to take it in and have a mechanic check it. Yikes that could be very costly. Thanks for the info. I will let you know if that does work. Thanks again.
blackhillsdeb
10-05-2005, 07:51 PM
Any battery drain is caused by something pulling voltage. If it drains as fast as you say there may be a light on somewhere in the car. Check the glove box, trunk light, under hood light. If they are all off when they should be you will need to do a systematic test by checking each circuit. To do this pull each fuse and check the circuit with a volt meter to see if there is any draw on that particular circuit. This takes time and if you have a dealer do it, it will cost a lot of money.We have checked there is no lights on. That was the first things we checked. My husband started to try and isolate the draw. I made him take it to work yesterday and it would not start at all even after the battery being charged all night. We have purchased an alternator, I am truly hoping this will take care of the problem. If not I imagine we will have to take it in to a mechanic to isolate the problem, my husband's schedule is grulling and does not allow alot of time to work on vehicles anymore. Yikes.............Thanks for the info, I sure hope the alternator will solve my problem.
