1997 B3500 Brake rotor help
Bestworkvanever
10-02-2005, 09:13 PM
My trusty work van is in need of a brake job.
She has 230,000 and runs like a champ and still
looks great.
I want to replace the rotors, calipers, wheel bearings, seals,
and do it up.
My van has a 400lb front axle and all wheel abs.
This is according to the sticker under the hood.
It has 8 bolt wheels with 1/2 studs.
Does the rotor seperate from the hub assembly...
or is it one unit? What do I get...whole deal or just rotor?
Which one? I am i need of help.
Dave
restrorob
10-06-2005, 08:02 PM
Does the rotor seperate from the hub assembly...or is it one unit? What do I get...whole deal or just rotor?
Dave
From what I can tell the rotor does in fact seperate form the hub but you can get the whole assembly also if you want. (hub also) And if you go that way make sure your sitting down when they give you the price.
