Should I use ports?
kicker1_solo
05-16-2002, 01:53 AM
Ok, I'm going to be making a sub box like this one.
http://images.cardomain.com/installs/28000-28999/28951_9.jpg
http://files.automotiveforums.com/uploads/873902137642_20_full.jpg
With the subs facing the front of the car that you can see when you lay the backseat down. I was wondering if I should use ports like this one, one on each side gonig up through the rear deck. It will be a sealed box. Do you think I should use the ports?
http://images.cardomain.com/installs/28000-28999/28951_23.jpg
sparq
05-17-2002, 01:05 AM
Ummm, if its a SEALED box you cant have ports... SEALED = SEALED and PORTED = w/ ports
Duhhey :flipa:
I say do what you like, personally I think the ports in the back deck look corny
kicker1_solo
05-17-2002, 01:09 AM
well I mean that it's going to be sealed if I don't have the ports in there. I don't care if the ports look corny, will they make it louder? And would it be hard?
sparq
05-17-2002, 07:49 AM
No not hard, and a ported box if setup correctly will easily run +3dB louder then sealed.
GSteg
05-17-2002, 07:20 PM
even with a sealed box, at least bass can travel through the rear deck better:D i say port it:)
kicker1_solo
05-18-2002, 03:59 AM
I've decided not to use ports. :)
