Reset Oil change light help??
Sp3cops70
10-01-2005, 12:12 AM
How do i reset the Change Oil Soon Light??? Thanks in advance...
Ridenour
10-01-2005, 10:58 AM
Open the fuse panel on the side of the dash. There should be a red button that says "RESET". Hold it down for 10 seconds.
StevePT
10-01-2005, 11:23 PM
I'm not sure if they changed it throughout the years, but on my 97 GP, I turn the ignition to on (don't start the car), then pump the accelerator pedal three times and then the light starts flashing. Turn off the ignition and it's reset.
regalfriend
10-02-2005, 07:38 PM
I have a 97 Regal GS....There is a drivers information display...its tells MPG's, oil life etc...when switched over to the oil life screen push and hold the reset button until oil life says 100%
rbsteve
10-03-2005, 07:31 PM
as StevePT said, turn to ignition, pump the gas pedal quickly 3 times, and you have to wait about 5-10 seconds and it will start flashing, start the car and you're set.
never heard about a reset switch though...different models, different systems i guess
