how do I bleed the gas rail
gemini1968
09-30-2005, 07:25 PM
I need to bleed the gas rail on my 1988 toyota pick-up. :feedback: HELP!
fourwd1
09-30-2005, 09:10 PM
There should be a shrader valve (like on a tire) at the end of the rail.
A hose with a screw on fitting will release the gas into a suitable container, or use something pointy to push in the stem, gas will spray everywhere.
gemini1968
10-01-2005, 05:24 PM
OK, I tried that but there's no gas going thru. I only have an 1/8 of a tank of gas, could that be the reason why I don't seem to have any pressure in the line? Thank You
fourwd1
10-03-2005, 03:53 PM
It means there is no pressure in the line, which is what you were looking for judging from your origianl post.
To get pressure, just turn the key to ON w/o starting the engine. The fuel pump should run and pressurize the line.
