95 S10 Blzr interior lights stuck on???
wildfireracing
09-29-2005, 10:54 PM
ok, i give up. my interior lites are stuck on (bulbs unplugged right now)
we have replaced both front door poppers (the little pin that is pressed down when the door is closed), the dimmer switch, interior light control module - not the problem....has anyone had this problem and solved it?? also got the rear door poppers, haven't had time to change them yet and i guess the last one would be the cargo door-but if its not one of these, i am totally stumped - HELLLLLLPPPPP! this showed up right after the shop guys fixed my door pins/bushings....any connection there?
XblazinLV
09-29-2005, 11:38 PM
Wow I'm stumped on that one.....good luck. Let us know when you get it fixed
JA no Y
09-30-2005, 12:09 AM
Check the cargo area switch to make sure it isn't on. I took a box out of the cargo area of my 95 and the lights stayed on constantly afterwards. I knew my 88 had a switch in it so I checked on my 95 and it had one too. I didn't realize it had one since the lights came on automaticly when I opened the back glass. It should be next to the actual cargo light.
wildfireracing
09-30-2005, 01:00 AM
i will, but i got a couple clues from the site!
wildfireracing
09-30-2005, 01:03 AM
i know about that one, i have it turned off so it wont stay on....lol
i've got a couple clues from my search-i will let you all know when i get it fixed!!!
Cailen
09-30-2005, 03:53 PM
Anyone have access to a wiring diagram for the interior dome lights? I'll check my haynes when I get home.
wildfireracing
09-30-2005, 09:04 PM
that would be helpful, let me know, the other hint i have is the drivers side door handle switch, but i think its inside.
