Changed Fuel pump relay not working?
GTP COUPE
09-29-2005, 08:13 PM
I changed the fuel pump relay and still nothing. All the terminals seem to be doing what they are suppose to but the fuel pump is still not coing on it works when I jump terminals. Very Baffled?????????
GTP COUPE
09-29-2005, 08:15 PM
1997 GTP
BNaylor
10-02-2005, 08:28 AM
Just how are you troubleshooting this problem? Do you have a wiring diagram for the circuit and are you using a multimeter? Still sounds like the fuel pump relay is not energizing.
http://i5.photobucket.com/albums/y186/lizzywiz/gtp.jpg
Thrasher CAI, DHP v1.0 PCM, SLP Headers,
3.25 SC pulley, CAIT GMAF, 2.5 DP/Hi-Flow CAT,
u-bend delete, 160 TS, ZZP Stage 1 72mm TB,
TB spacer, MSD 8.5mm wires, Autolite 103,
Goodyear Gatorback Serp. & SC Belt,
Nitto NT555R Drag Radials
1/4 ET: 13.210 sec. @ 104.490 mph
0 - 60 ft: 1.945 sec.
