94 Intrepid Tranny Problem
rebby
09-28-2005, 09:13 PM
Car has about 60K miles. The car shifts fine between all gears. When the car has been running for about 10 minutes and I slow down, at about 5 miles/hour it jerks hard into 1st gear. When I accelerate everything is fine and it down shifts into all gears OK until 1st gear. When slowing down if I brake hard before I stop you can hardly feel the problem. When I slow down and throw it into neutral before I stop, again you can hardly feel a problem. Fluid level is fine and I recently added in Lucas Tranny treatment. Didn't really do anything. Any ideas.
theFREAKnasty82
09-28-2005, 10:10 PM
#1 thing to remember with Chrysler transmissions, PLEASE NEVER ADD ANY ADDITIVES OR OTHER FLUIDS TO THE TRANSMISSION. You will screw things up in a heartbeat b/c these transmissions are very sensitive to the type of fluid you use in them. Your original problem is something that occurred in the first few years of this transmission called bump stop. Read this article (http://www.allpar.com/fix/trans.html)for more details.
rebby
09-30-2005, 03:36 PM
I just went to my local tranny repair shop. They hooked up a computer and found no bad codes. He drove he around the block with the computer on and must have re-programmed something beacause the problem went away. Best part was he didn't even charge me, so I'll go back and have them replace the fluid and filter. Thanks :)
