Tint Removal
soul180
05-15-2002, 12:13 PM
Hey, when i first got my car i wanted it to look cool right away, so, like most people i tinted the rear windows BLACK.....now, i have my car done up, custom paint and stuff, and the tint makes my car look cheap...i'm wondering how to take the tint off...I imagine with a razor i can take the side window tint off...but what about that rear window with the defrost lines...can anyone help me out? Thanks in advance
JayFidizzy
05-15-2002, 12:43 PM
Scape it and use ammonia or vinegar to get the glue off.
soul180
05-15-2002, 12:58 PM
but u can't scrape it with those defrost lines there, they'll scratch off, won't they?????
JayFidizzy
05-15-2002, 01:48 PM
hmm good question...i would just try and peel to see what happens.
soul180
05-15-2002, 01:54 PM
well that's what i was going to do, but i'm jsut worried i'm going to get half way done, then get screwed and have half tinted glass..hmmm....
Do you think it'll look better wihtout tint? I see you have it on your civic, but you're is darker and looks better...my car is light now, i dunno, i justg feel that it clashes
98civicex
05-18-2002, 02:53 PM
they sell some window tint removal stuff at the local stores. you spray it on and put some suran wrap over it and let it set for a while. then you can just peel it right off. i made the mistake of scraping my back window and now i have no rear defrosters.:confused:
onesojourner
05-18-2002, 03:18 PM
yep gp tp walmart they have it there
sparq
05-18-2002, 04:30 PM
DONT USE THE SYRAN WRAP TO COVER IT UP!!!!
I removed the tint on my front windows, on one side I bagged it up, the other I didnt... the side I sealed up, came off in litle pieces, the other side which I didnt cover up... came off in one piece.
You are correct, DO NOT scrape the lines as they will come off... however you will most likely need a razor blade to start the removal... just be carefull, and pull slow and steady and you should get it all off. Then spray more tint remover off and let it sit a bit to get the glue thats still left off... repeat that till its all gone.
emadboy200
05-18-2002, 05:09 PM
i used a heat gun, and the spray to take off my tint. what ever residue was left on the window I took off with grease remover, and windex. :D
1993HondaCivic
no do this is works perfectly
rip off all the the tint. there will be glue left.
get fine steel wool. FINE!. and some strait ammonia.
use the two to get the glue off.
works!
works!
