Check Engine light????65?????
Nackattack
09-28-2005, 12:13 PM
I have a list of the codes and my engine light is flashing 65 and there is no 65 on the list!!! What is up with my car, just got oil changed yesterday!!
superbluecivicsi
09-28-2005, 01:15 PM
assume this is obd2.
65 = secondary o2 sensor.
reset ecu. if it comes back, more than likely your o2 sensory is a goner.
~ls/vtec~
09-29-2005, 12:08 PM
i had a problem like that at one point. i changed my o2 sensor like 5 times. turns out i had a bad ecu. it was fine at first but later is started throwing the light. after you reset the ecu if it comes back, replace your o2 sensor. if the light still comes back then check the wiring to the sensor. if its all good then replace your ecu. or you can find somebody with an obdII ecu and plug the ecu in just to make sure
Nackattack
09-30-2005, 12:41 AM
Hey thanks guys...Will it be fine to drive on till I can get that secondary o2 sensor?
superbluecivicsi
09-30-2005, 12:49 AM
yes, it will be fine.
~ls/vtec~
09-30-2005, 02:19 AM
the secondary o2 sensor is there pretty much just to tell you if your catalyc converter is good or not
Nackattack
09-30-2005, 01:03 PM
Hey thanks for the quick responses, now I can sleep at night. You guys are the shi@#!!!
