Truck is driving me crazy........
Speed350
09-26-2005, 08:01 PM
Ok.... I think this truck is cursed. I have a '93 pickup with a 22re. The problem is it is idiling like crap. It will idle high for a liitle while and then it will start loping, rpms going up and down. When I apply the brakes it damn near stalls out and then it will rev back up continuing to lope, just more severe then when I am not holding the brake. It does this constantly. I have replaced the valve cover gasket, pcv valve, fuel filter, check all the vaccum hoses visually and with ether, and ran seafoam through it. Nothing is working and I am beginning to lose my patience. I have talked to a few people who work on cars around here and they can't figure it out. It seems to me to be a vaccum leak, but I can't seem to find the damn thing. ANY help would be appreciated.
Thanks. :banghead:
Thanks. :banghead:
bjd088
09-27-2005, 12:43 AM
I've heard of that on other cars, have you checked the fuel pressure regulator? (I'm not sure of the location on your truck)
Brian R.
09-29-2005, 04:09 AM
Clean your IAC and EGR valves
LayneP
10-12-2005, 06:52 PM
Maybe your brake booster is lbad and is giving you a vacuum leak. Have you checked for stored trouble codes yet?
kingweevle
10-13-2005, 01:39 PM
Try the self diagnostic sustem to see if there is some trouble codes.Sometimes this will guide you to the problem.
