power windows on 96 EB explorer w/flasher
jolinejb
09-24-2005, 01:53 PM
I tried to change my flasher relay, power windows worked fine before I did so. Then it made a buzzing sound and windows didnt work after that. So i put the old one back in. Is that the wrong relay I switched or does the windows also belong to the flasher. If is is wrong then I cannot find the location for the flasher because it matches identical to whatever makes my windows work. PLease help
exploded99
09-24-2005, 07:04 PM
I have a 99 v8 which has the turn signal flasher under the cover on the steering column - near the hazard lights switch behind the steering wheel. Not sure about yours, but I am thinking its similar.
You might have ruined your new turn signal flasher.......
jolinejb
09-24-2005, 08:43 PM
I switched them at the auto parts store, then i exchanged it for another one thinking maybe it was a defective flasher. My windows work fine with the old flasher i had, just not with the new one. so im wondering does the flasher and windows go together on the same relay.. weird
exploded99
09-25-2005, 01:57 AM
Ok, just to be sure here - are you trying to fix your windows by putting in a new relay, or are you trying to fix your turn signal flasher? Where was the relay you replaced?
jolinejb
09-25-2005, 09:19 AM
No my windows are fine with the old flasher i had. My turn signals dont work w/ the old flasher or w/ the new one. I switched the flasher that is located under the dash to the right of the steering column. it was in a black box. There were about 6 or 7 plug things and it was the big one in there. When i went to the auto parts store asnd asked for a "flasher" thats what they gave me and its exactly the same size and a 5 prong just like the old one. When i put the new one in, it buzzed, ticked, windows didnt work, turn signals still didnt work. So i exchanged it for another one thinking maybe that part was defective, but it did the same thing with the other new one. So i put the old one back in because everything worked with that one except the signals & hazard lights and there was no buzzing. So now im still driving around with the old one in there but with no signals. Windows are fine. Thanks
kjsweb
09-30-2005, 12:22 AM
Have you checked the power window fuse?
B33p3r
10-01-2005, 08:24 PM
98 SOHc and mine is also in the steering column.
exploded99
10-02-2005, 12:30 AM
The only way that makes sense is if the auto parts store gave you the same wrong part twice, which would not surprise me.
You might try Ford - take your flasher in with you to the parts counter to make sure you get the right one. It will cost a buck or two more I spose, but it will work.
jolinejb
10-02-2005, 02:56 PM
Yes i did it! iT WAS THE POWER WINDOWS RELAY I HAD ACCIDENTLY SWITCHED, no damage though. The flasher is located on the steering column in a yellow box looking thing that is actually a plug if you pull it. Whew! About time. Now i have working signals again. The repair manaul had told me it was on the side of the steering column, maybe it is for a regular explorer, but not for an eddie bauer's. Thanks all for your help.
