intermitent cooling problem
92zcamaroperson
09-23-2005, 09:03 PM
My fans arent coming on sometimes. That would indicate a motor goin bad wouldnt it? Anybody know where there is a fuse block diagram for a 92 camaro is online. My manual has a pic but it looks like an older style block. So im not sure which fuse goes to the fans. That and wheres the relay that kicks them on? Im thinking its the motors or the temp sensor that engages the fans in the first place.
ct91rs
09-23-2005, 11:17 PM
The relay is at the rear of the engine, on the driver's side of the master cylinder, mounted on the firewall. I can't imagine the fuse would be less than a 20A, so I would check all the 20's, and larger. The temp sensor is on the passanger side, in the block, between cylinder's 6 & 8.
supervisor1886
09-24-2005, 02:17 AM
just wire the motor to the batery and see if it runs.
If it does that its either the relay (Take it apart and see whats going on)
Or the CTS switch thats located in the manifold under the TP (The small one)
Or bad connection.
I have a manual switch and a relay hooked up
92zcamaroperson
09-24-2005, 09:24 AM
Cool. I read in a old post somewhere about a green wire that I can ground out that should kick the fans on. Where is this wire attached? This really sucks cuz not only are my front brakes draggin because of a bad proportioning valve but now my car overheats.....POOP!
