Coolant over flow leak from Res.
Mrmaceman
09-22-2005, 06:40 PM
Hey, I have a o1 GA. I drove home from work 2 day and when I parked for a few minutes I noticed there was a small amount of coolant on yhe ground. I checked under the hood and did not c any visible leaks. Then I checked the Res. tank and noticed a small stream running along the engine compartment. Anybody got any ideas on what it might be? Thermostat? Thx The Man
xeroinfinity
09-23-2005, 10:55 AM
These reservoirs on GAs are strange. They overflow easilly(essepecailly when ran hard in hot weather). Does the reservoir look low ? If not I wouldnt worry to much just yet. You can prop the hose end up higher by placing the hose behind the cruz controls lines. this will keep it from what i call the syphon effect, it overflows and the vaccum pulls out more coolant than it should. My 99s always loosing alittle coolant(about half gal a year) from the overflow, even though i hav the hose proped up. Could be needing a new cap on the reservoir too. If the leak persists try taking off the reservoir and cleaning it out this may help.
Mrmaceman
09-24-2005, 01:42 PM
Thank u very much, and to your ? about the res being low, I had to add some dex just before the summer began. Because the low coolant light came on and also when I removed the cap it came off in two pieces, first the cap then there was a plug if some sort. I will try the first suggestion u recomended so thx again, Peace...The Man
xeroinfinity
09-24-2005, 04:40 PM
My res cap was in two peices too. The pieces snap back together, but they dont stay together, I just bought a new one recently. I'm always ADDing coolant in my 99'. If the low coolant light comes on, I immediately check the level. My wife ran it low one day and cooked all the oil out too. Luckily it didnt ruin the motor.
Mrmaceman
09-25-2005, 01:42 PM
Thx, was not sure if it was suposed 2 b, I will try a new cap and c if that makes a difference. Later The Man .....
