Repairing a cracked transmission
sejo_tt
09-21-2005, 08:50 PM
Well folks bumped my transmission and got a fine crack on it noting major, It’s just that area is wet oil is not dripping from it but when you pass your hand you get some, Anything I can use to fix it any type of special epoxy that I can use, The transmission is working fine So I don’t want to change it Thanks.. :):)
Greenblurr93
09-21-2005, 09:12 PM
jb weld that shit!!!
sejo_tt
09-21-2005, 09:21 PM
Yeh thanks I thought of that but what type of welding will work best on that thing, It’s aluminum welding it wouldn’t cause any problems right ??
Greenblurr93
09-21-2005, 09:32 PM
NO, "jb weld" is a type of epoxy... clean the area and dry it, plaster some if it on and let it sit for 24hours... hard as steel.
sejo_tt
09-21-2005, 09:35 PM
Thanks will try
Smoghog
09-23-2005, 04:51 PM
Thanks will try
JB Weld is a great addition to any tool box. It will seal cracks in radiators, thermostat housings, and works on exhaust leaks too.
Works on aluminum, steel, plastic, and more. It has saved me a bundle of cash.
It will work.
SH
