For Richtazz
97GreenGTP
09-21-2005, 06:50 PM
Hi Rich,
Thanks for the info on SC tensioner.I really appreciate you offering me that at a lower price than the dealer retail price.
I was also looking for some other parts,see if you can help.
1. pig tail for the passenger side fog light(In the bumper:was changing the bulb and due to rust, broke one of the bulb's pin in the socket)
2. Trunk light assembly with the bulb i beleive
3. SC coupler
Thanks again
richtazz
09-22-2005, 12:55 PM
One part was easy, the fog lamp connector:
delco # PT331 $12.49
On the other two parts, I'm not sure what you're asking for, what do you mean by the s/c coupler and do you need the entire tail-lamp assembly with the bulbs and sockets, or just the bulb sockets?
StevePT
09-22-2005, 07:17 PM
I believe by S/C coupler he means the plastic piece which connects the impeller gear to the output shaft. It's the piece inside the housing that will wear out and create a "rattle" in the S/C at idle.
BNaylor
09-23-2005, 09:40 AM
Maybe this will help Rich:
http://www.zzperformance.com/products.php?id=106
BTW - I'll get back you with on the stuff I need.
http://i5.photobucket.com/albums/y186/lizzywiz/gtp.jpg
Thrasher CAI, DHP v1.0 PCM, SLP Headers,
3.25 SC pulley, CAIT GMAF, 2.5 DP/Hi-Flow CAT,
u-bend delete, 160 TS, ZZP Stage 1 72mm TB,
TB spacer, MSD 8.5mm wires, Autolite 103,
Goodyear Gatorback Serp. & SC Belt,
Nitto NT555R Drag Radials
1/4 ET: 13.210 sec. @ 104.490 mph
0 - 60 ft: 1.945 sec.
richtazz
09-23-2005, 10:05 AM
thanks guys, I'll do some digging and get back with you
97GreenGTP
09-23-2005, 02:04 PM
I am not looking for tail light.I am LOOKING for the trunk light.I think its the GM part # 10273135.
And on the coupler, Steve is right. The coupler in the SC that rattles when the holes get bigger.
richtazz
09-23-2005, 02:12 PM
gotcha , I've been a little busy today, so I'll get back with you.
