D18Y8 ignition timing.
rginter
09-20-2005, 12:49 PM
I just rebuilt the engine and put it back in the car. I need to set the timing. Does anyone know the settings?
Greenblurr93
09-20-2005, 01:35 PM
i think your crank pully has 3 notches on it...with your timing guns set to 0, and the sevice connector jumped and the engine brought up to temp... set it so the middle notch is lined up with the little plastic fin on the cover.
rginter
09-20-2005, 01:37 PM
Where is the service connector?
Greenblurr93
09-20-2005, 01:40 PM
under your dash, on the pass. side. its a little green plug that has nothing pluged into it... mine had a silicone (green) protective case on it... jump it using a thin paper clip or i used speaker wire.
rginter
09-20-2005, 03:31 PM
Thanks. I never would have figured it out by myself.
Greenblurr93
09-20-2005, 04:54 PM
go to www.helminc.com (http://www.helminc.com) and buy the service manual for your car. it will have EVERYTHING you could ever do for your car....with pics and torque specs...
