Towing package has trans cooler?
Jon6873
09-16-2005, 02:06 PM
I have a 02 with the tow package. Is it supposed to have a trans cooler already installed?
I looked around the radiator and could not see a smaller radiator which usaully is for the trans cooler.
cdru
09-16-2005, 03:43 PM
On my 98, the transmission cooler is built into the radiator. Look along the passenger side of the back of the radiator about half way down. Do you see two metal tubes coming out of the radiator? If so, yours is like mine and the cooler is built in.
You may want to consider adding a seperate cooler in addition to the built in one (or bypass the built in one all together. Check with a local tranny shop if you want to further investigate the option.
