rear end question
loggerman76
09-16-2005, 03:42 AM
whats the best was to make my rear end positive track and still use it as a everyday driver its a 91 rs with a 7 5/8 10 bolt?
ct91rs
09-16-2005, 06:57 AM
Whether a car has posi-traction (limited slip) is independent from it being a daily driver.
You basically have two ways of doing it.
1. Swap the carrier. (The very center of the differential behind the diff. cover that has the ring gear and spider gears). Have a posi carrier installed.
2. Swap the entire rear-end. (wheel to wheel, the entire assembly)
You could keep the gear ratio you have now, or go to a gear set that's a little higher, either way it will be streetable.
demon9766
09-17-2005, 01:52 AM
Buy an eaton posi and have it put in.
