3000GT Alternator
NVETHIS
09-15-2005, 12:07 PM
I have a 1997 3000gt sl, sohc. Will a '97 dohc alternator fit in my car? Thanks.
- Bryan
Stealthee
09-15-2005, 04:55 PM
- Bryan
They are different.
Stealthee
09-15-2005, 07:50 PM
Dunno how I misses it before but if its a SL it is a DOHC. If its a 97 SOHC then its a base.
exterra3000gtsl
09-16-2005, 12:00 AM
you will fry the battery
Stealthee
09-16-2005, 12:04 AM
Huh??? Why do you say that. The altenator would work if it bolted up but the casing is different and the wiring is slightly different. Thats all. Other than that they are the same internally. Some DOHC alts got a higher amp output though but that still wouldnt fry the battery
exterra3000gtsl
09-16-2005, 01:00 AM
well then it will overcharge the battery and then it will boil it...then it will dry it...he doesn't have enough electrical demand like the dohc engine or the sl package...which in an easy street language we say..."fry battery)
Stealthee
09-16-2005, 07:46 AM
Sorry but you are dead wrong. People have actually gutted a DOHC altenator and put it in the insides of a SOHC alt to have the higher amperage. Guess what. It worked just fine.
Just to disprove ya a little more what about base 3k's and ES Stealths?? They dont have as much stuff as a SL now do they? Yet they run the same alt.;)
Twizted_3KGT
09-16-2005, 10:33 AM
A higher amperage alternator won't fry a battery unless the voltage regulator in it is broken...it's not gonna suppy any charge past 14-15 volts. So what im still wondering is...is your car an SL or a base NVETHIS??
