need answers
hotcar92'
09-11-2005, 08:41 PM
i jut got my 92' rs camaro. it has been runnin great w/ a new motor n brand new trans. the only problem i hv w/ it now is when im sittin at a red light or just completely stopped n i gun it all i hear is a thumpin noise. i hv no clu as 2 wut it could b. some1 thinks its the driveshaft. but i hv no idea.. ne thoughts?
hotcar92'
09-11-2005, 08:42 PM
it sounds like its cominfrom the back rite rear of the car..have ne 1 of u ever had this prob?
ct91rs
09-11-2005, 09:03 PM
You snapped your transmission mount.
Sounds like I hear my own echo...
Rally Sport
09-11-2005, 09:06 PM
Im still trying to understand what he's asking..
ct91rs
09-11-2005, 09:30 PM
Not to be a dick but I do prefer english myself. :wink: I think what he ment is that when he tromps on it from a stop, he get's a big thump seeming to come from the rear end.
The tranny mounts are made partially of a hard rubber, and when you crack it, this is exactly what will happen.
666_speed
09-11-2005, 09:46 PM
sounds like the problem im having lol....would it be possible to break the tranny mount from bottoming out? when i get on it i can feel like something tapping under the car...at first i thought it was the exhaust got ripped loose but it seems okay....
ct91rs
09-11-2005, 09:53 PM
not really, there's a cross brace that runs perpendicular to the trans, from one sub-frame to another. The trans mount is located between the trans and the cross-brace. Over time the mounts fatigue, and torque eventually snaps them.
ct91rs
09-11-2005, 09:55 PM
You can't really tell if they are snapped or not unless you support the trans with a jack and remove the brace, and then the mount will probably fall in half.
supervisor1886
Bull shit. It would make noise when you put the gas to the floor, because the U-joint actually contacts the body.
ct91rs
09-11-2005, 10:00 PM
Alright tuff guy. Seletive reading I guess. If you noticed in his post he described a noise coming from where it would hit. I'm simply saying that you'd have a difficult time actually seeing that it's busted unless you do as I described.
kahjdh
09-12-2005, 01:13 PM
It might be a bad u joint.
Savage Messiah
09-12-2005, 01:24 PM
IF you stomp it from a stop and hear/feel a clunking coming from somewhere in the middle of your car, get under there and check the tranny mount and torque arm bushing. If broken, replace with poly and don't worry about that problem again.
KickinCamaro
09-12-2005, 02:35 PM
sounds like the mount to me as well..
from what your sayin it reminds me of my old celica and it was the Mount
hotcar92'
09-12-2005, 08:41 PM
ok well im 16n this is my 1st car..its a 92' rs camaro..n im just not sure wut was goin on. bc i could get on it w/ no real problem. now when i try to get on it i get the thumpin noise. it lasts not long mayb 4 3 seconds then it is gone. i hv no idea as to wut it is. but wut does this sound like n how much 2 fix?
88camaroproject
09-12-2005, 08:51 PM
i replaced mine about 2 weeks ago. its like a 30 minute job at the most. jack the car up, put on jack stands, support transmission, take bottom middle bolt out of crossmember, unbolt 4 outter bolts that connect crossmember to subframe, let the crossmember fall (or catch it), umbolt the 2 bolts holding mount to transmission, bolt new one up and bolt cross member up and then the middle bolt to the mount, then lower car and drive. when your old mount come out if it was the problem it will be in 2 peices. a new one thats the same costs like 8 bucks and a polyurathane one is like 20 i think. it takes no real skill to do. just some socket wrenches.
88camaroproject
by the way im 16 too
BLU CIVIC
09-12-2005, 08:54 PM
i kinda hear the same thing in my moms 92 rs...gun it from a stop and i hear a noise
hotcar92'
so its the mount then ? u hv had this problem b4?
88camaroproject
09-12-2005, 09:15 PM
when i would stop my trans would slide up just enough to bounce the y ipe around and it was annoying. i dont think my 2.8 is fast enough to twist my tranny far enough for the u joint to hit the body. but it is possible. what engine u got?
hotcar92'
09-12-2005, 09:17 PM
3.1L v 6. when i stop nothin slides up. just when i gun it when im completekly stopped i hear a thump 4 3 seconds then its gone
88camaroproject
09-12-2005, 09:38 PM
if you jack up yur car and you can wiggle your transmission around with a crow bar then your mout is shot.
ct91rs
09-12-2005, 09:41 PM
I'd say it's the mount, I broke a few when I had an '89 (didn't replace them with poly).:smile:
88camaroproject is right, it's really not that hard to change, I changed my first one at 16 too - had no clue what I was doing. :cool:
Genopsyde
09-12-2005, 10:18 PM
Blu Civic, I love your sig.
Matt365
09-12-2005, 11:16 PM
whats up with the hot asian chick dancing.
Rally Sport
09-13-2005, 12:09 AM
:iagree: I've been looking at it for about 5 minutes straight. :boink:
Wonder what Jim would say about it.
Savage Messiah
09-13-2005, 02:23 AM
good god where did you get that sig/whats it from/who is it...
hotcar92'
09-13-2005, 07:14 PM
how much does a new mount cost to fix? i can do it on my own tho rite??
hotcar92'
09-13-2005, 07:16 PM
n wut is the reason 4 it breakin?
BLU CIVIC
09-13-2005, 07:17 PM
well i have a bet going on about how long it will last...i've had better in the past, but was asked to remove it...some girl from myspace
Rally Sport
09-13-2005, 07:18 PM
If you're talking about that skinny tap dancing girl or whatever it was... IT WAS NOT BETTER.
88camaroproject
09-13-2005, 07:58 PM
that should get the freaking awesome sig of the week award. by the way whats her myspace name lol. any ways, yes the trans moount is easy and cost like 10 bucks, it just gets worn out.
Rally Sport
09-13-2005, 08:39 PM
Damn Civic, the new one aint that good..
BLU CIVIC
09-14-2005, 07:08 AM
well i got asked to remove it...soooo i gave my opnion :)
Rally Sport
09-14-2005, 08:47 AM
Well dont listen to em! FIGHT THE MAN!
BLU CIVIC
09-14-2005, 08:56 AM
you know what happens when you fight the mods
Viper_Storm
09-14-2005, 08:59 AM
you get added to their shit list? aint that right john? :p (or in johns case the 'you suck list')
lol, j/k
