overheating
ken31mechanic59
09-11-2005, 01:58 PM
i am working on a 96 caviler and changed out the water pump,thermostat,and changed temp sensor.still overheats...what could be the problem?? it has green coolant not the dex cool...
FinchUsed
09-11-2005, 02:45 PM
Heater core? I think thats what its called. My beretta had to have a new one put in because I would drive for 15 minutes and the sucker would overheat.
Ryan066
09-11-2005, 04:51 PM
clogged/rusted out rad?
air in the system?
jakegday
09-11-2005, 06:31 PM
whens that last time you had your cooling system flushed?? not just your radiator but everywhere the coolant goes...
deadBird
09-11-2005, 09:18 PM
Don't forget to burp the air.
cdru
09-12-2005, 12:21 PM
Does the cooling fans kick on? At what temp are they kicking on when if they do? Does it overheat if you put a large box fan in front of the radiator and run it on high as the car idles?
ken31mechanic59
09-12-2005, 11:39 PM
the fan kicks on at 225'f . i replaced the temp sensor and relay...whatelse could it be???
cdru
09-13-2005, 09:26 AM
Does your upper radiator hose get hot/hard? If so, you have coolant flow but it's just not getting cooled down. How do the fins look on the radiator? Are they rotting out, bent, filled with bugs, etc? You many want to pull it and have it looked at, having it flow tested to make sure it's not plugged or something.
ken31mechanic59
09-14-2005, 12:26 AM
yeah it does get hot...fins look good and no bugs...ty i think i may take radiator out and have it looked at and cleaned...ty for the advice..
deadBird
09-14-2005, 03:53 AM
If it overheated severly, you may have blown a head gasket. Also if you've never changed that water pump, now would be a good time. Don't forget to bleed the air out and flush the entire coolant system with something like Prestone Radiator flush.
EDMUND65
09-14-2005, 12:17 PM
blown head gasket, i have had two.....
