sloppy idle..almost hiccups
yesiownonetoo
09-11-2005, 01:53 AM
at idle it has erratic miss fire, worst in gear (auto),changed plugs,wires, roter, and ignition control mod...2.8l v-6,'85...vacuum or sticky valve?..whatcha think?
wildcatsua
09-15-2005, 09:49 PM
Any starting problems or SES light? My 96' had same rough idle. After months after trouble shooting turned out to be the fuel pressure regulator.
drdd
09-15-2005, 11:44 PM
check the simple stuff first ...
u got the wires routed correctly? double check them !
have you messed with the distributor? could it be 180 degrees off?
u changed the pcv lately? cleaned egr?
what brand plugs are u using?
