putting turbo in.
91 Eclipse
09-10-2005, 11:21 AM
Well i have finaly decided to keep my car and sometime in the near future im going to go to a junkyard and get all the stock tubo parts for my car. Maniflod, Turbo, Intercooler, Intercooler piping, Wastegate, BOV, Down Tube and i dont know what else. if someone could please make a list as to what i need to get all the stock parts it would be greatly appreciated.by the way i think i might be getting a t25 or a 14b not for sure yet which one should i get?
91 Eclipse
09-10-2005, 03:29 PM
I think i need Manifold, Turbo, Downpipe, Intercooler, Intercooler Piping, BOV, Wategate, Oil feed lines, O2 sensor Housing, Turbo Timer, MBC, Intake Piping, Intake Filter, Gaskets, Fittings, Sleeves am i missing anything and what turbo would you uys recommend 14b or t25?
Thor06
09-10-2005, 03:53 PM
Get the 14b. I think you will need an install kit for a t25 should you choose it, but the 14b can make more power and you will have the easier installation.
91 Eclipse
09-10-2005, 04:06 PM
thats what i was thinking about getting iand i think thats what ill do but now does anyone know if i was missing anythingin my second post.
91 Eclipse
09-10-2005, 09:04 PM
any help would be appreciated.
mitsu_eclipse95gst
09-10-2005, 09:10 PM
Dont use the old gaskets get new ones. Does he need the ecu and fuel system?
SLoe
09-10-2005, 10:14 PM
ECU and wiring harness to go with it I believe. www.vfaq.com , in the 1000s of already answered questions section.
LouieAWDTSi
09-10-2005, 11:02 PM
Yea stick with the 1g set up and get the 14b. Don't forget about all your coolant lines too. What about your engine compression? N/A 4g63 is diff then 4g63t compression. Might wanna get some good advice on that too. Good luck I almost when that route before I found my awd tsi.
ez1286
09-11-2005, 02:20 AM
You might (im not too sure) also need the oil pan so you have somewhere to bolt the oil return line from the turbo.
91 Eclipse
09-11-2005, 11:12 AM
ill just tap the oil line right into the oil pan but so far i need, ECU, Wiring Harness, Oil Feed Line, Coolant Lines, Gaskets, Turbo, Intercooler, UICP, LICP, Manifold, O2 Sensor Housing, Down Pipe, BOV Wastegate, Turbo Timer, MBC, Intake Filter, Intake Piping that sounds like thats about it but not for sure.
91 Eclipse
09-11-2005, 08:30 PM
anything im missing just making sure i have everything.
LouieAWDTSi
09-11-2005, 10:12 PM
Well you dont NEED the turbo timer. Not a bad idea to get one of course.
