found an engine
Pimpdady753
09-08-2005, 09:18 PM
ok i know i had a bunch of questions about the 351 i was going to put in my car, but i think i found the engine im going to get, was just woundering what you people think about it,
http://www.coasthigh.com/Assemblies/Crate_Motors/427_injected_venom.htm
and how hard do you think it will be to put this eninge in, i herd it only takes new headers, new engine mounts, and possibly a new hood. thanks.
BigDanTheMan
09-08-2005, 10:04 PM
what year and options do you have
Pimpdady753
09-08-2005, 10:58 PM
its a 1990 Gt with a 302 some what moded just the normal no big mods done yet. cold air intake, flow masters, bbk heads witha X pipe no cats, msd intion, msd coil, ait con taken off, and im not sure what gears are in the back, and idea on how to tell. thanks.
fordtrucksonly
09-08-2005, 11:10 PM
Your gonna spend 13,000 bucks on a crate motor?
BigDanTheMan
09-08-2005, 11:26 PM
does the air cleaner rest on top of the manifold on that?
Pimpdady753
09-09-2005, 01:02 AM
im not totaly shure, and did you read it, its a 351 that is a 425 cubic inches that makes 550 hp dud.
SkylineUSA
09-09-2005, 02:45 AM
Your gona boost on top of that? If so, you are going to have major problems, dude! Its a great crate engine, but your body is going to twist up like a pretzel.
Pimpdady753
09-09-2005, 08:40 AM
im difintly not going to be able to get a supercherager this year so i dont have to worry about that this summer.
SkylineUSA
09-09-2005, 10:19 AM
Then that engine is almost perfect, but it has too many cubes for my taste. I like an engine that can rev a little more and last a little longer than that one, but to each his own.
Pimpdady753
09-09-2005, 11:41 AM
what do you mean it has to many cubes, whats wrong with cubes, and what do you mean rev a little higher and last longer.
SkylineUSA
09-09-2005, 01:33 PM
Its just the way I like my engines, too long of a stroke is not good on an engine if you want it to last a certain amount of miles. I doubt that engine would last more than 40k, unless you babed it all the time. That is a very long stroke, that is all I am saying.
Pimpdady753
09-09-2005, 04:00 PM
for real, what is going to happen to it.
351wStang
09-09-2005, 05:12 PM
Listen to Skyline ( I got your back bro :bigthumb: ). Thats over a 4" stroke dude! Can you just imagine the side load that engine will see? Even with those lightweight probe pistons and 4340 rods that thing is gonna wear the shit outta your cylinder walls and in a damn hurry. Ya thats a great engine if you want to stop by every gas station you see and fill up. Then pull it apart about once a year to check for wear to make sure there isnt anything you need to fix before it breaks. Sure it would be a fun engine, but as Skyline said, it wont last long. I just couldnt justify that kinda money for such an engine. Buy a Dart Iron Eagle block (they make both 302 & 351w based blocks), 4340 crank/rods, Mahle or Probe pistons, TFS Hi-Ports, Weiand Xcelerator, CSU 750, and a turbo. You will have basically have trouble free tuning, more power and daily driver capable, for that kinda cash! But if your sold on EFI which is fine, I still say you can do better than that by putting together your own combo. I'm like Skyline, thats just too many cubes for a street driven small block motor. Thats why I didnt stroke my windsor even when my machine shop wanted me to stroke it to a 410. .030" overbore is all I did and that was because I had to. Well, .020" over would have been fine but in order to "true" the cylinders & ease of pistons, I let them punch it out .030". :2cents:
SkylineUSA
09-09-2005, 05:25 PM
Yep :D
Pimpdady753
09-09-2005, 06:21 PM
ic thanks
BigDanTheMan
09-10-2005, 12:56 AM
essentially they are saying study up and build your own, and for that kind of bread you could pimp out a sick block.
SkylineUSA
09-10-2005, 02:37 AM
1k on the the carb and bonnet
1k on fuel
1.5k forged internal
.5k block
1k valve train
3k turbo T76
1.5k wide band, and other gauges
.5k roll cage
1k brakes
1k suspension
1k for exaust and aftercooler
2k heads
1k C4
2k for the car (R32 GTR)
1k tires
1k rims
And still going! This will give you an idea where I am at.
If you look at just the engine, its complete at the same price for the one pimp listed. And I can self tune. That 10k engine pimp listed will run you another 3k for fuel, exhaust, tune, etc. But what do I know?
1k on fuel
.5k block
1k valve train
3k turbo T76
.5k roll cage
1k brakes
1k suspension
2k heads
1k C4
1k tires
1k rims
Pimpdady753
09-10-2005, 08:00 AM
ic thanks
