help
justinjustin
09-07-2005, 03:30 PM
i have a 96 gmc jimmy 2wd 4.3 v6 and it cranks but wont start i replaced the spider injectors and new fuel filter and new fuel pump and still wont start i rplaced the relays as well, i hear the pump come on and also took it out of the tank and tested it ,i replaced the mass air and new spark plugs, anybody have any ideas ??thankyou
drdd
09-07-2005, 04:44 PM
what's your fuel pressure reading at the Schraeder valve?
you got the plug wires routed correctly?
justinjustin
09-07-2005, 10:34 PM
i havent checked the fuel pressure ..the plugs are correct i did it 1 by 1 so i wouldnt mix it up .
drdd
09-07-2005, 10:41 PM
check that fuel pressure and report back.
also, check your battery voltage ...
u got a haynes or chilton manual ?
QUOTE=justinjustin]i havent checked the fuel pressure ..the plugs are correct i did it 1 by 1 so i wouldnt mix it up .[/QUOTE]
justinjustin
09-07-2005, 10:43 PM
my next step is to hook it up to a scanner to see maybe i can pull some codes ..
BlazerLT
09-09-2005, 10:09 PM
You really need to start listening to people here.
If you are not going to listen to us, don't ask us for help.
He asked you to check the fuel pressure, DO IT!
justinjustin
09-10-2005, 01:39 AM
ok can you tell me the best way to check the fuel pressure ? no i dont have a haynes .thankyou justin
BlazerLT
09-10-2005, 02:01 AM
Get a fuel pressure gauge, hook it up to the schrader valve, turn the key to the on poistion and see what pressure it is putting out.
justinjustin
09-10-2005, 11:16 AM
the schrader valve , is that near the t/b on the right side ?looks kinda like a bike tube stem?
drdd
09-10-2005, 09:01 PM
yes, it looks like a bike tire valve. Put a rag under there because you will get a small burst of fuel when you connect the fuel gauge to the valve.
take two readings:
1) key on, engine not running
2) engine running (at idle)
report back
take two readings:
report back
