How do I change dew wipes?
Crashdocs
09-06-2005, 10:33 AM
This is my next fix..... the Outside dew wipe on both the passenger and drivers side door. Tried to do this over the weekend, had the door panel off and the indoor wipe off.... noticed you can't get to 2 or 3 of the screws holding the wipe on. Do I need to take the window out of the door to take this off and replace it? One more fix for this thread, the brake dinging and light keep coming on everytime any movement with the ebrake in it's unengaged position. Should I loosen up the cable slightly to prevent this? Thanks yall
Old Lar
09-07-2005, 01:18 PM
www.rodneydickman.com sells a "special" tool that will give you access to the dew wipe screws. Otherwise you can take out the window to access the screws. Click on the GALLERY" to see the first photo. The inside door panel was removed and the glass is shifted out of the way to gain access to the screws.
Ragtop_Renegade
09-07-2005, 09:24 PM
There is a small limit switch inside the parking brake lever housing that turns on the brake light, yours must be loose or broken from it's mount, causing a false trigger of the light. You'll have to take the plastic trim off to get at it. It's possible you can fix it with some good 'ol JB weld, otherwise it's a phone call to Kick Hill to dig up a replacement.
Crashdocs
09-08-2005, 07:52 AM
Thanks, I'll check that out. Looks too simple, go figure....
Crashdocs
09-08-2005, 07:53 AM
Another thing to get fixed this weekend before i get the inspection done, time to tag it.... Thanks for your help
Jason
